4R100 check ball question - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-21-2011, 03:45 PM
4R400 with no rev and no 3rd after rebuild.
large check ball in the valve body in the most forward spot was mission.
will this cause this problem or can it be the stuck accumulator valve I found
in the accumulator body?
Bob
700r4 check ball location question ruined344 Transmission - Rearend 6 03-10-2011 05:32 AM
68 gto ball upper ball joint removal question adam83 Suspension - Brakes - Steering 25 01-04-2011 01:39 AM
turbo 400 check ball trouble antiquehorse1 Transmission - Rearend 9 09-01-2008 07:18 AM
4L60E check ball location? gemini86 Transmission - Rearend 11 04-18-2006 09:02 PM
57 Hydra-matic check ball MeligN Transmission - Rearend 3 04-15-2004 06:29 AM
