4R70W no go - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-08-2006, 08:53 PM
4R70W no go
Hello all, I just bought a 1994 Lincoln Mark VIII 4.6 DOHC V8, 4R70W trans. with transmission troubles. The guy I bought it from told Me that reverse quit working a while back,and He drove it for 3,000 miles in forward only. Now reverse works but no forward motion at all. I am wondering if this could be something electrical? Seems to Me if it was mechanical reverse shouldn't be able to not work before but start working when forward quit. I have a used transmission from a same year 3.8 V6 T-bird, but I don't want to pull it if I don't have to. Thanks
Old 09-09-2006, 12:32 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
no forward movement is not an electrical problem with that trans.
Old 09-09-2006, 10:38 PM
Arrowhead's Avatar
EFI Rules and Carbs Drool
Last wiki edit: The FREE T Bucket plans
Last journal entry: Sold Everything for a new project
Wiki Edits: 5
I agree, you can totally disconnect the electrical harness and it will operate P-R-N-2 (limp home mode) The automatic shifting is controlled by shift solenoids energized by the computer. Sounds like you have a mechanical problem though. Better check real good to make sure that other tranny will swap too.
Here is some info on these transmissions.
http://www.tccoa.com/articles/tranny/#
Page down on this one and here is a chart that shows which solenoid is energized for each gear
http://www.mn12performance.com/mn12-...w_rebuild.html
Lot of Ford transmission talk here too:
http://forums.tccoa.com/forumdisplay.php?f=13
Ford 4R70W Transmission won't shift 2-3 Arrowhead Transmission - Rearend 2 04-30-2006 06:22 PM
4R70W behind 351W in pickup??? macx Transmission - Rearend 2 05-24-2005 10:19 PM
Difference AOD-E & 4R70W General01 Transmission - Rearend 1 05-02-2005 08:09 PM
AODE / 4R70W assembly question Csele Transmission - Rearend 4 11-02-2004 07:05 PM
4R70W and Baumanator msureb Transmission - Rearend 0 11-19-2003 01:29 PM
