4t60 problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-18-2003, 07:35 PM
Post 4t60 problem
I have a 94 berretta with a 4t60 trans. It will shift all four gears fine but after four or five mile warm-up it will not shift into OD. Any ideas as to what could be the problem? Thanks
Old 04-20-2003, 09:13 AM
airworld2's Avatar
Post
Thinking this trouble maybe lock up rather than 4th gear, have you had it scanned for codes at trans shop.If not lock up internal trouble,dont think shift solenoid trouble.You would lose two gears typically, shift valve sticking would indicate metal.
airworld2
