Demon carburetor Get parts for cheap, all for a good cause.
Parts auctions to protect free speech online.
Click here for details.
Parts currently up for auction: Rat rod chassis parts, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > Transmission - Rearend
  #1
Old 04-10-2007, 12:27 PM
david hill david hill is offline
4t60 Trans Question
I Have Built A Sand Car With A 96 Riv Motor And 4t60e Trans. I Am Running A 97 Program In The Pcm From A Gtp That Had A 4t65e Trans. My Trans Will Not Hold Manual Low. It Operated As If It Were In Drive. I Have Checked The Trans Range Selector Switch To Insure The Pcm Is Being Told The Trans Is In Manual Low. All Checks Out. I Am Able To Get The Car To Hols First If I Disconnect The Speed Sensor. Does Any One Know Why The Pcm Would Tell The Trans To Shift Prematurely.
Old 04-10-2007, 08:58 PM
Chazmac Chazmac is offline
Moderator
re: 4t60 Trans Question
Mostly 'cause it's programmed for a 4T65E???
All GM trans have a low gear override function that ensured engine life by limiting RPM in manual first. To change this function will require a VERY good valve body tech who has complete hydraulic charts.
No way around it...
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "4t60 Trans Question"
trans question fattyford Transmission - Rearend 13 05-10-2006 03:42 AM
Trans Am Gauge Search --not a tech question Ozz1967 Hotrodders' Lounge 3 04-19-2006 11:57 PM
Chevy 4l60E trans. Question whynot Transmission - Rearend 3 04-18-2006 09:36 PM
76 Trans Am Transmission question... jdauel Transmission - Rearend 2 04-14-2006 03:54 PM
th350 trans question levens Transmission - Rearend 4 12-21-2003 05:45 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
