4t60e transmission - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-20-2012, 12:27 AM
4t60e transmission
MY 1995 Chevy Beretta, has a 4T60E transmission. The Trans wont shift into overdrive. Shifts flawlessly all the way up to 3rd, but just wont get into 4th.What could this problem be? Also, b4 this happened it started making a whine sound. Thought it was the power steering but then this, no shift into overdrive happened.
Anyone with ideas? Truly appreciate it
Old 07-21-2012, 09:36 AM
check the fluid level
The Following User Says Thank You to dgcantrellsr For This Useful Post:
thump1st (07-22-2012)
Old 07-22-2012, 08:11 AM
Did that. Even drained the pan & put new fluid in it. Although for the last 3 days it hasnt been shifting correctly, it still has that whine sound to it.
Anyone else have any suggestions? And thanx to dgcantrellsr, for ur response
4T60E slips in all gears when cold? FULL-THROTTLE Transmission - Rearend 1 12-12-2011 12:46 PM
caddy 1995 4t60e ozzie57 Transmission - Rearend 12 07-20-2008 12:28 AM
4T60E transmission wem59 Transmission - Rearend 4 01-22-2008 04:12 PM
4T60E Trans chatter russlaferrera Transmission - Rearend 14 08-04-2006 12:07 PM
4t60e BstMech Transmission - Rearend 1 09-12-2004 07:43 AM
