-   -   4T65E-HD slips when hot after rebuild (http://www.hotrodders.com/forum/4t65e-hd-slips-when-hot-after-rebuild-193420.html)
redxaero 02-26-2011 02:40 PM
the transmission is out of a 98 GTP. trans did the same thing before rebuild. i replaced everything, clutches and steel plates, all sealing rings, all o-rings, new torque converter, new pump shaft, new 4th clutch shaft. its just got me aggravated. have looked for a post like this issue and havent found one. so here i am making one. hopefully some of you guys can be kind enough to help me out.
bbuss 02-26-2011 02:53 PM
4t65-e
what gear or gears are slipping?
redxaero 02-26-2011 03:05 PM
it seems to only be when i first take off. slips like hell but if i pretty much idle it it does ok, you can tell its slipping. but once in second it seems like its slipping but cant tell. other gears are fine.
redxaero 02-26-2011 03:25 PM
just retested the transmission and it is reverse too. but no other gears
