4T65E-HD slips when hot after rebuild
the transmission is out of a 98 GTP. trans did the same thing before rebuild. i replaced everything, clutches and steel plates, all sealing rings, all o-rings, new torque converter, new pump shaft, new 4th clutch shaft. its just got me aggravated. have looked for a post like this issue and havent found one. so here i am making one. hopefully some of you guys can be kind enough to help me out.
4t65-e
what gear or gears are slipping?
it seems to only be when i first take off. slips like hell but if i pretty much idle it it does ok, you can tell its slipping. but once in second it seems like its slipping but cant tell. other gears are fine.
just retested the transmission and it is reverse too. but no other gears
| Scarf cut sealing rings 4T65E | dgcantrellsr | Transmission - Rearend | 2 | 11-03-2010 08:00 PM |
| '93 4T60E - Same trans, different prob - Slips in low/reverse after rebuild | mjw | Transmission - Rearend | 15 | 04-10-2007 08:24 PM |
| th 400 slips in second. | LarryJS | Transmission - Rearend | 3 | 03-17-2006 05:22 PM |
| 727 slips from 2nd to 3rd | gorf24 | Transmission - Rearend | 4 | 08-20-2005 07:00 PM |
| No O/D.. slips in 1st | WDK | Transmission - Rearend | 8 | 03-13-2003 05:49 PM |
