4t65hd - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-24-2012, 06:16 AM
Rhansen's Avatar
Footbraker
4t65hd
in an '01 Buick Regal GS. Went to the dragstrip for the season opener and noticed the car was shifting about 500 rpm early. I tried disconnecting the battery for ~20 min or so and ran it again, the 1-2 shift was right at ~5750 on the tach but the 2-3 shift was still around 5200. Scanned for codes and pulled up a PO336 pending (crank position sensor fault).
Could the crank sensor cause the trans to shift early?
I know these cars will enter into 'abuse mode' if any wheelspin is detected in 2nd gear but am unsure if abuse mode will cause it to shift early and also doubtful that I was getting any wheelspin in 2nd (couldn't hear/feel anything unusual).
I was running 225/50-16 hankook race tires on the front, stock tire size is 225/60-16 - could the shorter front tire have been a problem? Was expecting a 'low tire' idiot light with the shorter fronts but it did not come up.
Hoping somebody will have an idea what is going on.......
Old 04-24-2012, 08:07 PM
pricesgarages's Avatar
if its goes in to a abuse mode it will set a 1811 maxium shift adapts and will shift real firm the tire diameter could effect get the ecm reprogramed to your desired shift points is what u auctally need
Old 04-25-2012, 06:24 AM
Rhansen's Avatar
Footbraker
maybe I wasn't clear but something changed. I've had this car to the track off and on for the last 5 yrs and it always shifted around ~5750 on the tach. Usually grabs 3rd just before the finish line.
I have mismatched tire sizes before (front to rear) and it didn't effect the shifts but did light the 'low tire' indicator. maybe the 225/50's are close enough to stock that it wont trip the dummy light - I dunno.
Old 04-25-2012, 09:12 AM
I had a 99 Regal GS 3800 for years as my DD. I used to run snow tires on it in the winter and they were a little taller than the summer tires on the factory 5 spokes. I never had an issue; in fact I had to drive it on a donut spare for a couple days and I never had an issue either. Maybe the trans needs an adjustment?
Old 04-25-2012, 10:29 PM
theres no adjustments on wot the tps sensor can be moved for part throttle shifts lager tires would make it hold shifts longer in therory
2001 4t65HD possible problem Rhansen Transmission - Rearend 11 11-06-2008 08:07 PM
