4th Generation F-Body Pre-LT1 Stroker Motor Swap & Computer Question - HELP ! - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-30-2007, 09:27 PM
To All,
I want to swap an earlier, large SBC stroker motor into a 1995 Z/28. The LT1 will be removed in favor of a fuel-injected 454 World Products setup. The Computer will be a stand-alone aftermarket unit for the Fuel-Injection only and the Transmission will be a T56 (GM/VIPER) 6-Speed manual, etc . . .
QUESTION: How much of the "rest of the car" does the Factory Computer run / control ? Can the stock computer setup be totally removed and have all accessories, instruments, etc. function normally ?
The LT1 motor is just too limited, unless you spray it, blow it, or turbo it . . . Also, the largest possible cubice inches is only around 396-400 +/- . . . There are no suitable aftermarket parts for my application for the LT1 either . . .
WHAT ARE YOUR THOUGHTS ???
***MORE INFORMATION***
The car will NOT have to pass any type of "Sniffer" emissions test, since only 1996 & up OBD-II cars do in NC ( That's why I want to use a 1995 ! ) only thing is a visual "Safety Inspection" . . .
Dave Fitch
Louisburg, NC
Dave Fitch
Louisburg, NC
Last edited by ez2cdave; 05-30-2007 at 09:35 PM. Reason: additional information was accidentally left out
"Basics of Basics" Sectioning a Body MARTINSR Body - Exterior 7 11-24-2008 01:04 PM
383 Stroker Question thebellman Engine 3 02-01-2007 03:56 PM
Vacuum and Intake/Throttle body Question. elcrusch1 Engine 4 10-06-2006 10:36 AM
