Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 4wd to 2wd conversion
Old 01-20-2006, 03:06 PM
M&M CUSTOM's Avatar
M&M CUSTOM M&M CUSTOM is offline
Wiki Edits: 9
Remove the four wheel drive transmission, transfer case and driveshafts.
Replace with a two wheel drive transmission and a longer rear driveshaft.
Nothing detrimental will happen to the truck with all of the four wheel drive components left in the front end of the truck, whether they are used or not.
