-   -   4wd to 2wd conversion (http://www.hotrodders.com/forum/4wd-2wd-conversion-79184.html)
burninrubbah617 01-18-2006 03:02 PM
If I have a 97-2000 ford f 150 or a silverado whats the most convinient way to convert the 4 wheel drive system to rear wheel drive?
Henry Highrise 01-18-2006 03:12 PM
There is no convenient way...you have to change the frontend out then eleminate the transfer case etc. and put in a longer driveshaft. It would be much simpler to just sell the 4 wheel drive and buy a 2 wheel drive.
351fairlane 01-18-2006 09:13 PM
Just leave it in two wheel drive.
Rob Keller 01-19-2006 09:14 PM
Take out the rear drive shaft.
HEY!
You didn't say which wheels you wanted to drive off of :D
Sorry I just couldn't resist :evil:
:thumbup:
M&M CUSTOM 01-20-2006 03:06 PM
Remove the four wheel drive transmission, transfer case and driveshafts.
Replace with a two wheel drive transmission and a longer rear driveshaft.
Nothing detrimental will happen to the truck with all of the four wheel drive components left in the front end of the truck, whether they are used or not.
