4wd to 2wd conversion - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-18-2006, 04:02 PM
If I have a 97-2000 ford f 150 or a silverado whats the most convinient way to convert the 4 wheel drive system to rear wheel drive?
Old 01-18-2006, 04:12 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
There is no convenient way...you have to change the frontend out then eleminate the transfer case etc. and put in a longer driveshaft. It would be much simpler to just sell the 4 wheel drive and buy a 2 wheel drive.
Old 01-18-2006, 10:13 PM
Rev It Loud, Drive It Proud!
Just leave it in two wheel drive.
Old 01-19-2006, 10:14 PM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
Take out the rear drive shaft.
HEY!
You didn't say which wheels you wanted to drive off of
Sorry I just couldn't resist
"SlowRide66"
"Illegitimis non carborundum"
Old 01-20-2006, 04:06 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
Remove the four wheel drive transmission, transfer case and driveshafts.
Replace with a two wheel drive transmission and a longer rear driveshaft.
Nothing detrimental will happen to the truck with all of the four wheel drive components left in the front end of the truck, whether they are used or not.
700R 2wd or 4wd whats the difference?? Mighty Mouse S-10 Transmission - Rearend 5 06-08-2005 09:48 PM
4wd to a 2wd.. frame info 53fordguy General Rodding Tech 9 12-14-2004 06:03 AM
700R4 trans conversion to 70' C10 2WD steve d Transmission - Rearend 5 01-31-2004 02:56 AM
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 04:34 PM
2WD TH350 to 4WD TH350 rambo_z28 Transmission - Rearend 6 07-17-2003 06:17 PM
