4WD Chevy frame?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-18-2007, 04:06 PM
4WD Chevy frame??
thinking of putting my '67 C10 stepside longbed (whew!) onto a 4x4 frame of correct-length & such. What frames should I look at. Suburban ?? (67-72 or 67-80??), C10 4x4 is an obvious choice, just wondering what alternatives there were like the Suburban...
Old 11-18-2007, 04:42 PM
poncho62's Avatar
Wiki Edits: 5
Pretty sure the 67-72 long box and the Suburban are the same frame. I also think that the 73-80 is a whole different frame.....not saying that it couldn't be made to fit. I put a 77 Ford PU on a 73 Blazer frame.
Ontario Rodders
Old 11-18-2007, 05:30 PM
ryork's Avatar
38 LaFayette
Last journal entry: Got a little help..
Seems like I remember that you have to cut out part of the floor and add a hump to clear the transfer case..check the donor truck and if it has the hump you could cut it out and weld it in.
Bob
Old 11-18-2007, 06:07 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
The 4x4 trucks---both AT and MT have a different floor.
The major difference is a hump under the seat----or rather the 4-spd tunnel hump of the 2-wheel trucks ---- will extend to under the seat.
So---if you have a 2-wheeler-----There WILL be loor modifications regardless of whether you plan on running an AT or MT.
Cutting a section from a donor would be a good idea.
Bryan
Old 11-18-2007, 07:34 PM
A guy here in town put a 2wd on a 4wd frame and took care of it with a small body lift, I'm guessing 2 or 3", maybe that would would instead of the floor mods...
good to know the 73-80 isn't the same...
Old 11-18-2007, 07:42 PM
poncho62's Avatar
Wiki Edits: 5
Not positive that the frame is different, so don't take my word for it........I have been wrong before..........ask my wife........
Ontario Rodders
Why not use your current frame and get the needed parts off of a 4x4?
Shane
Old 11-18-2007, 07:45 PM
poncho62's Avatar
Wiki Edits: 5
Shane
Thats a lot more work tahn changing the frame............they are a totally different animal.
Ontario Rodders
Old 11-18-2007, 07:59 PM
Yeah it would be coil spring rear wouldnt it?
Shane
Old 11-18-2007, 08:15 PM
stoneshrink's Avatar
Buickguy
Last journal entry: And now the new project
Depending on the year, the Sub frame the truck frame are different... I wish I had used a Sub frame under my Studebaker (see project page) because the Sub frame is flat as opposed the truck frame which has a kick up right behind the cab.... as it was it worked out fine, but required a bit of reverse ingenuity (no, not reverse engineering that is far too bookish for what I did)....
You may wish to splice and dice the frames together - I've seen it done on other projects and, while it may seem more work, in the end there are some definate advantages to cutting and pasting the truck together - such as not having to refab cab mounts, not having to change the rear brake lines, etc......
Old 11-20-2007, 03:07 AM
krue's Avatar
New Member
Last journal entry: Fenders
You should check out www.67-72chevytrucks.com , lots of good truck specific info there.
Old 11-20-2007, 05:45 AM
thanks... I'm not much of a welder either, I'd have to have a buddy do that or maybe take the welding class
thanks for the website, looks good.
37 chevy frame swap novanut Hotrodders' Lounge 2 02-22-2009 09:27 AM
frame swap for 1950 chevy p/u chevykid33 Introduce Yourself 2 08-13-2007 10:05 PM
53 chevy pickup frame change robert forshee General Rodding Tech 8 01-11-2006 08:30 AM
37 chevy coupe frame nomadbb Suspension - Brakes - Steering 2 02-18-2005 04:32 PM
53 chevy cab fit on to 75 chevy frame king of obsolete General Rodding Tech 7 10-14-2003 01:50 PM
