4x2 to 4x4 conversion - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-27-2012, 09:31 PM
I just bought a 92 sonoma 4x2 because my 98jimmy 4x4 is falling apart. I was told that the 4x4 components would bolt in because th sonoma has a 4x4 blazers rear end. Is this true or would it cost a fortune? I'm confused some say yes and some say no
Old 07-30-2012, 06:32 PM
bigdog7373's Avatar
Of course it's fast
It wont be bolt in. 2wd and 4wd trucks have a bunch of different parts. Steering, suspension, even the exhaust. Just about everything in the front will have to be converted. Very very time consuming.
Another option would be to put a straight axle under it, which is what i would do. Much less work than ifs.
Old 08-15-2012, 10:58 AM
GMCBEAST's Avatar
Not sure of wheelbase of the two, but it might be easier swapping the Sonoma body to the Jimmy frame. You may get lucky, I know on the older fullsize trucks it's the way to go. Hardly any modifications needed.. Hope this helps.
conversion
4x2-2-4x4 Stoynkee Introduce Yourself 4 08-11-2011 07:46 PM
chevy 1500 4x4 trans into a 4x2 hellraiser509 Transmission - Rearend 4 12-30-2009 11:27 AM
S15 4x4 conversion jesse01 Engine 4 04-20-2006 05:53 PM
4x4 conversion..... 53fordguy Hotrodding Basics 11 03-01-2004 07:48 PM
S10 4x4 Conversion? MartyMart9@aol.com Transmission - Rearend 11 02-17-2004 10:36 AM
