4x4 - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-17-2007, 02:32 PM
4x4
i need to pull out a cvc shaft in a cheve luv truck its a 80 i need to know how to pull out the shaft i dont know what im dooing on this becase i never pulled one out on a 4x4 i have on a front weel drive those r a snap are these like a front wheel drive or diffrent can any body help me out
Old 01-17-2007, 08:31 PM
poncho62's Avatar
Wiki Edits: 5
Is it the front driveshaft or the front axle shafts that you want to pull?
The driveshaft is easy...just unbolt the "U" bolts and it comes out.
The axle shafts, you have to pull the front hubs. Special socket needed to get locking nuts inside of hub. Take that off and axle slides out
Old 01-18-2007, 04:57 PM
4x4
this is on a luv do i need to drop the tie rods and upper and lower ball joints is there spensions bars i need to take off
4x4 steering problem adrock430 Suspension - Brakes - Steering 10 12-05-2005 05:39 AM
2x4 to 4x4 changeover ? bowtieorbust Suspension - Brakes - Steering 3 06-20-2004 07:20 PM
Launching a 4X4. Rubberman2003 Hotrodders' Lounge 6 03-02-2004 03:06 PM
87' Bronco 2 4x4 One touch 4x4 button IAMCANADIAN Electrical 1 02-08-2003 03:49 PM
87' Bronco2 4x4 won't work IAMCANADIAN Transmission - Rearend 1 02-06-2003 12:44 PM
