4x4 1994 Trans problems ???? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-16-2007, 06:16 PM
I Have a 1994 4x4 chevy truck,it used to have a v6 in it and i believe it was all computer controlled(eng.and trans.), now it has like a 327 or 350 chevycarb motor in it,im not sure what trans it is i think 700r4 it says MD8 on housing...my question is, this trans has been rebuilt 2 times by a good trans rebuilder and it has went out again....only goes in reverse no forward gears im pretty sure its burned up fluid is black what trans do i put back in it.......
it does have the 4 pin plug on the drivers side of trans but only one wire is hooked up....
im confused please help thanks
shaun
ohio
Old 07-16-2007, 06:30 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
shaun
ohio
Is the TV cable on the trans hooked up and adjusted correctly.
Old 07-16-2007, 06:37 PM
yes i just checked after you asked , thats the cable that goes of the t.b. and down to the right side of the trans
Power and Fuel Econ Porblems with NEW STOCK 1994 350 TBI MuscleBlock81 Engine 12 09-08-2009 11:01 PM
More Geo tracker problems junkyardjeff Electrical 1 01-16-2007 02:15 PM
1994 trans am jo5hi3 Transmission - Rearend 1 05-25-2005 08:42 PM
Lineup problems big time FiefSS Hotrodding Basics 1 06-27-2004 10:31 PM
Tranny help in a 79 Trans Am BudLight Transmission - Rearend 2 04-13-2004 08:01 PM
