Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 4x4 axle conversion ttb to solid front axle.
Old 10-31-2005, 11:54 PM
Jared's Avatar
Jared Jared is offline
I can get the dana 60's for 250.00 in 3.5:1, 3.73:1 limited slip, or 4.10:1 the bronco is an 83. the suspension mounting I was told is the same or very similer... I know I have to attach a panhard mount and since I dont have a front crossmember where the older trucks had it I will have to fab that all up. other than that I noticed that the radius arms mount to the trans cross member as well as the frame so I need to make a mount to simulate the stock crossmember. hmm sounds like fun wheelin.
