Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 4x4 axle conversion ttb to solid front axle.
Old 11-02-2005, 06:29 PM
M&M CUSTOM's Avatar
M&M CUSTOM M&M CUSTOM is offline
Wiki Edits: 9
If you are going to swap a leaf sprung axle under the front of the Bronco, you will have to fabricate much less, and there is also a possibility of swapping stock parts from other years to direct fit what you need.
Only a possibility, as I am not nearly familiar with fords as I am with GM trucks.
I know of a few manufacturers making solid axle swap conversion kits that simply bolt on to the existing frame, but with that one I am only aware of up to the 1998 model year.
