5.0 Ford with 600 Holley DP - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-03-2005, 06:13 AM
I have a 89 Ford 5.0HO mustang motor in my 73 Bronco. The cam and heads are stock with an Edelbrock performer manifold. The carb I have on it now is a 600 Holley DP. Tranny is C4 auto. Is this just too much carb. I have a 7.5 PV in it, 65 mains and 73 jets in secondary. Before I put the 65 in the primary, I would get lean spots at part throttle. But now at crusing speed the motor seems pretty rich.
I was thinking about opening up the power valve restriction holes and jetting down on the carb. What about putting on a billet Quick Fuel metering block. It says that it has jets for the PV restrictions.
Maybe I just have too big of a carb, but I really dont feel like buying a new carb.
Any advice.
Old 06-03-2005, 09:14 AM
Max Keith's Avatar
600 Dp
You definately dont need a DP with automatic, however, a vacuum secondary 600 wouldnt be overly large. I would recommend going down to a 500-550 CFM carb with vacuum secondaries. You just cant use all that 600 with your stock heads and cam. A 500 would carry you well past 5500 RPM. I would go with a smaller carb, get better throttle response, and even some nominal increase in gas mileage.
Ford 5.0 vs Chevy 5.0 1meancuda Engine 21 06-13-2006 08:57 PM
Ford Race Engine BarbWire Engine 7 10-18-2002 11:38 AM
Ford 5.0 internal specs 50Ford F1Panel Engine 15 10-05-2002 09:51 AM
5.0 ford install gerry Engine 1 06-18-2002 01:48 PM
New 5.0 Liter Ford mustang66maniac Engine 3 03-06-2002 08:10 AM
