5.0 Ford Crate Motor - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-27-2005, 10:22 AM
Irelands child's Avatar
I posted this on another thread several days ago, but no response, so....
Have the lengths of the two SVT 5.0 oil pump drives been measured? I have in my 1999 crate motor (originally an EFI engine) the SVT M-6605-A302 and possibly need the -B302 to mate up properly with my steel geared MSD 8579 Pro Billet distributor. The -A302 seems to be about .500 too short as it only engages the dist. hex drive about .25 +/- of the .625 depth and my guess is that .500 to .5625 would be best for long engine life.
If push comes to shove, McMaster - Carr and some .250 hexstock would work - but only as a very last resort.
Help!! Thanks
Irelands child
Old 12-27-2005, 10:44 AM
Help!! Thanks
i just inst older dist in my 5ltr i am building the oil pump entered but will remove and see how much is engaged. the fi dist is way longer but splines ar also longer i asumed newer fi dist used more spline to eliminate twist. looks like another lesson, will post my findings. cliff
Old 12-27-2005, 04:05 PM
5l oilpump drive
5l efi distributor has 5/8ths more spline thanearlyer dist. early dist has 3/8 full ccontact for oil pump drive, checked some older hex drives and out of 3 they all had only 3/8 drive contact. unless the efi drives ar shorter looks like ther is more contact onefi. one could use a hex from yblock and shorten to give more contactat dit end. i would think with a stock oil pump 3/8 would be plenty of drive, cliff
Old 12-27-2005, 06:40 PM
Response to Cliff
Thanks Cliff - I appreciate you looking at this. Maybe I really don't have any problem after all - though I do have a Melling HV pump rather than a stock OEM - had to change the pump and pickup when I went to a front sump oil pan - which turned out to be useless because I am using IFS instead of the I-beam axle that I originally planned, but that's another story.
I also am using a 302(5.0L) rather than the 351W's that usually power my cars.
Dave
Irelands child
HO 350ci 350 crate motor info trog Engine 9 01-22-2011 02:23 AM
Ford GT-40 Crate Engine Questions 31rdster Engine 8 11-27-2005 02:32 PM
ford 5.0 help needed 1969NovaSS Engine 7 11-26-2005 08:08 AM
To Crate Motor or not to Crate Motor wickster Engine 2 09-15-2004 10:49 AM
Ford 5.0 internal specs 50Ford F1Panel Engine 15 10-05-2002 09:51 AM
