5.0 ford distributor woes - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-20-2007, 08:04 AM
59 wagon man's Avatar
hello i am putting together an engine for my 59 ford wagon . the engine is a 5.0 roller motor of unknown origin.my problem lies in the distributor which seems to be from a 1994-95 5.0 f.i. motor. the shaft seems to be longer than the earlier years ,so my question is what kind of distributor can i replace this with in order to convert this engine to a carb. thanks
Old 02-20-2007, 08:59 AM
the engine spec and casting date are located on the flat ledge above the starter.....larger characters are spec, smaller are casting
post those
Old 02-20-2007, 10:18 AM
6F8 does that seem like the right numbers? thanks red.
Old 02-20-2007, 11:09 AM
xntrik's Avatar
Save a horse, Ride a Cowboy.
6= 86 (80's since it is a roller block)
F = June
8 = 8th day
Old 02-20-2007, 11:12 AM
thanks xntrik so i guess the distributor thats in the motor is incorrect because it looks like a 94-95 with the extended shaft
Old 02-20-2007, 11:33 AM
xntrik's Avatar
Did Ford make 5.0s for the Explorer in 96?
I'm not sure of the distributor shaft difference. I'm sure a Ford expert will chime in shortly.
KULTULZ probably knows the difference. Duke is the resident "Ford data expert" here, IMO.
Either way the oil pump drive shaft length might be the only difference, since the cam, etc. is always in the same place.
The roller cam will require the distributor drive gear from the roller distributor be installed on your "conventional" distributor you are using with your carb.
Aftermarket I like MSD. Conventional, use the Ford Duraspark from the late 70s.
Old 02-20-2007, 03:01 PM
wagonman,
fair chance the oil pump shaft is not in a rotational position allowing the dist gear to mesh and drop all the way in?
or it's not a 95' 5.0 dist?
Advance Auto lists the same Motorcraft dist DA2010 for 86' and 95' and the same Clevite pump shaft xxx1412 for both
Autozone listed the same Cardone dist #'s, 86 and 95, xxx2880
take the 95' dist to a local store and compare it to a 86'
Old 02-20-2007, 06:43 PM
39 chev's Avatar
Last journal entry: new pictures of T-bucket
I posted this question some time ago.I was working on my buddys 48 ford truck with an injected 302 that we changed to a carb. There are definately 2 different length distributors.someone posted pictures of them side by side. We ended up getting a mallory unilite from jegs and it dropped right in.
Old 02-20-2007, 07:00 PM
glad to hear that 39 chevy just did the same thing hopefully i'll have the new unilite by friday
Old 02-20-2007, 07:07 PM
Wiki Edits: 31
could always fire a DSII with a MSD box, that's what I'm doing with my 200 Ford Turbo engine ( once it's put togther ). MSD even makes a connector harness to plug right into the Duraspark distributor, which is just over $15 from summit. it's part # 8869 I belive. I bought the harness.
Old 02-21-2007, 05:38 AM
aka Duke of URL
Originally Posted by 39 chev
I posted this question some time ago.I was working on my buddys 48 ford truck with an injected 302 that we changed to a carb. There are definately 2 different length distributors. someone posted pictures of them side by side. We ended up getting a mallory unilite from jegs and it dropped right in.
Old 02-21-2007, 07:40 AM
that is exactly how my dist shaft looks the one on the left now what about the oil pump driveshaft is there a difference
Old 02-21-2007, 09:19 AM
from the Ford Racing parts site:
6605-A302= shaft for 289/302 (longer?)
6605-B302= shaft for 87-95' (shorter?)
no demensions given....send them a email and ask for the demensions and post here......this "won't fit" dist question comes up repeatedly
you really should replace the shaft with a new one regardless....it is the "weak link" in the oiling system
Old 02-21-2007, 09:20 AM
nitro_baller4692's Avatar
floppers forever
the hevyduty shaft is 1/2'' longer ,thats what kultulz's post says
Old 02-21-2007, 10:26 AM
xntrik's Avatar
Wouldn't it be better to cut off the hex shaft instead of the distributor?
Ford 5.0 oil level problems xntrik Engine 7 06-30-2006 01:51 PM
Extra bolt holes in my 5.0 SB Ford Irelands child Engine 4 03-20-2006 06:17 AM
5.0 Ford Mustang 49dream Engine 6 03-14-2006 08:02 PM
ford 5.0 HO oldblue4x4 Engine 2 12-28-2003 08:06 PM
1994 ford mustang 5.0 DunscombK Engine 2 09-29-2003 12:01 AM
