5.0 ford install - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-18-2002, 12:59 PM
Post 5.0 ford install
Has any one put a fuel injected early 90's
ford 5.0L in a 37 ford . If so what Mod's were needed
to the fire wall ect.
I would like to install a overdrive Automatic
if possible
Old 06-18-2002, 01:48 PM
Post
Going thru the motions right now in a 32. Not sure how much clearance you have between the rad and fan but because of the length of the Ford block it is a tight fit.94/95 Mustang has a short water pump design and a special timing cover that will chop 1 1/2 inches for you,or you can buy a kit from March that achieves the same all using the serpentine. I am using a v groove regular flow short ford racing svo pump and the required pulleys to achieve the same result.
