5.0 going in a 1956 Ford Crown Vic. - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-19-2008, 11:20 AM
Farmerscot's Avatar
I have put a 91 5.0 HO with a AOD in A 1956 Crown Vic. I had to put a front sump oil pan on it to clear the crossmember. I wanted to keep the serpentine belt system but can't put a dipstick in the 91 timing chain cover with the serpentine set up. Any suggestions?
Old 04-02-2008, 09:53 AM
Wiki Edits: 27
bone yard scrounging
time to look at the salvage engine pile. some older engines had a dipstick tube rivited to the side of the oil pan find one and the dip stick. and try to weld it at the same relative height on the pan.. then when you refill the engine oil with the proper amount for the pan you are using,, I think some front sumps took 5 and some 6 quarts put in the dip stick and see where it reads then either shorten it at the handle or find a longer one until you have it reading correctly. when using engines out of a van they sometimes have a long dip stick and tube I have shortened them..
Old 04-02-2008, 11:33 AM
Farmerscot's Avatar
Thanks!
I figured that I would end up doing something of that nature but I didn't realize that some dipsticks were riveted to the pan. I will start looking for one. Thanks!!!!
Old 04-02-2008, 11:42 AM
nitro_baller4692's Avatar
floppers forever
ford motorsports svt catalog
Old 04-03-2008, 01:43 AM
JeffB's Avatar
No big Deal
I have a 5.0 in my '54 Customline,if you have the pan off(so the drill filings fall out) you just have to drill a 3/8" hole in your timing cover,the chrome dipstick and tube they sell at Autozone etc. for about $10 is like 68-70 Fords.Put a small amount of RTV around the base of the new dipstick tube and gently tap it in.Send me a pm & email if you want a pic.You do have to plug up the old side dipstick hole also.
Old 05-23-2008, 09:08 PM
Dale
Any pictres of your swop? I want to do the same for a 55 fairlane.
Old 05-24-2008, 02:29 AM
56 ford
My neighbour installed a 302 into his 56 Ford car. The crossmember would not allow him to remove the drain plug. The plug was at the back of the sump. Out came the engine. I relocated the drain to the bottom side of the sump for him and he reinstalled the mill. Little details... The pan was taken from a 1979 F-150.
Clint
Old 05-24-2008, 05:29 PM
JeffB's Avatar
[QUOTE=price]My neighbour installed a 302 into his 56 Ford car. The crossmember would not allow him to remove the drain plug. The plug was at the back of the sump. Out came the engine. I relocated the drain to the bottom side of the sump for him and he reinstalled the mill. Little details... The pan was taken from a 1979 F-150. Had he used a 65-70 Mustang pan and pump(aftermarket chromes are $40) he would have saved himself a lot of hassle,any 54-56 swap requires a front sump pan.
Old 06-05-2014, 05:34 PM
5.0 into a '55 ranch wagon
I am putting a '91 5.0 into my 1955 2 dr. Ranch wagon and am having trouble setting the motor in place. I switched the pan to a '65 Mustang and am trying to use the '66 mounts and the pan hits the cross member about 1/2 inch before the mounts meet the hole. What's up with this??? I heard this should just drop in?
Old 06-06-2014, 01:37 AM
JeffB's Avatar
Because you are using the WRONG mounts this will show you what to do:289-302-351W Swap mounts | The H.A.M.B. There are 1300+ members in my Ford Group and hundreds of SBF swaps have been done using this method you see in the pictures,the part numbers are also listed at the top these mounts are used on late model Mustang 5.0's your '91 5.0 probably had the mounts you needed already on it.The late Mustang mount is 1 1/2" taller no clearance problem and these will also fit with no alterations:Hedman 88400 Painted Exhaust Header Tube Size 1 5" Coll 2 5" Ford 255 302 | eBay And clear the steering box great.You might want to pm me when it's time to wire up the starter,the '91 5.0 has the "mini starter" PGMR.
Engine Swap for Crown Vic edge Engine 12 11-03-2009 10:38 PM
Ford Steel Wheel Tech wheelkid General Rodding Tech 9 01-07-2007 07:31 PM
Ford 5.0 vs Chevy 5.0 1meancuda Engine 21 06-13-2006 09:57 PM
info needed on 87 crown vic drivetrain tonylsg Engine 4 10-15-2004 09:53 AM
Ford 5.0 internal specs 50Ford F1Panel Engine 15 10-05-2002 10:51 AM
