5.0 help on flexplate - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-08-2006, 03:33 PM
i
have a 78 cobra putting a 87 5.0 trouble is it uses a 143 tooth flexplate 28oz it has a small bellhousing to clear the headers can any one help. thanks ron.
Old 10-08-2006, 06:07 PM
aka Duke of URL
D5ZZ 6375-A A/T 141T 9.25” Convertor Mounting Circle
Small block reciprocating assemblies have some balance. The compact lightweight crankshaft itself does not carry enough counterweights to achieve zero balance. Extra counterweight is cast into the flywheel and harmonic balancer bringing the entire assembly into neutral balance. Early engines use 28.2 oz.-in. external balance, while 1982 and later engines use 50 oz.-in. flywheel and 34 oz.-in. damper external balance.
You are going to have to have the origional flexplate balanced to 5.0L specs.
Old 10-08-2006, 09:52 PM
1969NovaSS's Avatar
turbo lag......yeeeeehaaaaaaw
There is a special flexplate that lets you use the c4 with a 5.0. They have them on summit but I forgot who makes them.
Old 10-09-2006, 05:20 AM
aka Duke of URL
The MUST II has a very small housing as it has to fit within the confines of the MUST II tunnel. The one you are thinking of is the 157/164T. He would have to modify the trans tunnel to fit a normal bell housing.
Old 10-09-2006, 11:36 AM
nitro_baller4692's Avatar
floppers forever
a 157 tooth and a 164 tooth bellhousings the difference is in the starter on the 157 is more inward towards the block thats were i have a problem with the 164, but you say your hitting the bellhousing?
Old 10-09-2006, 09:47 PM
1969NovaSS's Avatar
whoops. Forgot that year was still the mustang II's. sorry about that.
72 pontiac flexplate powerrodsmike Engine 2 08-07-2005 12:47 PM
Problems bolting TCI Converter to TCI Flexplate Ghetto Jet Transmission - Rearend 2 06-19-2004 08:48 PM
flexplate designs for SBC??? anglia48 Engine 1 06-07-2004 05:01 PM
Ford Flexplate spacing k2mooch Transmission - Rearend 9 01-05-2004 02:51 PM
Small Block Chevy 400 flexplate install novajohnb Engine 2 10-31-2002 03:53 PM
