Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 5.0 HO, Changed plugs/wires now starter won't turn over
Old 06-18-2004, 01:13 PM
Echofive Echofive is offline
IF it was me, im not sure how safe this is but if ur sure the hot ocnnection from the battery is hooked to the start securley and u still get nothing, run a hot wire from the positive on the battery straight to the starter, or just short the big wire on teh starter to the solenoid with a metal object, ie screwdriver. ull see if its the starter that is dead, or a short somewhere in the ignition wiring. do it with the key off to make sure it doesnt start on you.
