Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 5.0 HO, Changed plugs/wires now starter won't turn over
Old 06-18-2004, 02:59 PM
Slant3's Avatar
Slant3 Slant3 is offline
84 Mutt
Last journal entry: Steering column
Grandprix....Summit sells a kit that lets you remotly mount your solenoid e.g. on the firewall or fender-----for GM starters.. I would also go with a Ministarter. I've had two stock starters go on me. Higher compression engines should run a mini-high torque starter and you can crank her over even after long hot runs
