5.0 liter ignition timing - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-30-2004, 10:08 PM
GTpony's Avatar
I am new to hodrodders.com and this is my first post. I am having a problem finding the stock ignition timing for a1988 5.0L HO. I just aquired this engine. It was set up with NOS and unless I am mistaken the timing should be a bit retarded. I do not wish to run any NOS and am in need of the factory set timing. Any help would be greatly appreciated. Thanks.
Old 05-30-2004, 11:17 PM
Carbed95GT's Avatar
Evil as I wanna Be
Last journal entry: First time out in 8 months!
From the factory, the timing read anywhere from 6* (too little) to 10* (ok, but it could still use more). I find that they tend to run best between 12*-14*, depending on what grade of gas you use. BTW............
Welcome to Hotrodders!
Old 05-30-2004, 11:23 PM
killerformula's Avatar
Last wiki edit: Carburetor
Last journal entry: Clean up
Wiki Edits: 3
That much timing initial? Really? Most unmodified motors find their sweet-spot around 8 degrees initial, I find it hard to believe a stock motor running a roller cam and hardly any compression or duration would want 14 degrees! What about the total timing?
Your timing SHOULD be retarded, but only about 2 degrees per hundred horse, so it should be close (As that motor wouldn't handle much more than a 100 shot if that).
If you're having a problem with the performance, a former nitrous motor's smallest problem may be its initial timing....
K
Old 05-30-2004, 11:39 PM
Grumpy
Aaaa... wait a minute... WRONG SECTION!
Old 05-30-2004, 11:50 PM
2-manytoyzs's Avatar
Start those projects someday
Last journal entry: Divco - has been on the back burner
Base timiing (stock) on all EEC VI 5.0 is 10 deg.
Old 05-31-2004, 11:35 PM
10* is correct.
Be sure you disconnect the SPOUT connector before you set the base timing. Then be sure to reconnect it when you're done.
