If you use the intank pump be aware that if you use a return style regulator you will have pressure problems. The return line is too small to flow enough fuel to keep the pressure in the 7lb ballpark. I removed the injection on my 88GT and went with a carb. With the return type regulator the best I could do was about 15lbs until I replaced the return line. The factory line is what helps with fuel pressure needed for injection. Have any questions pm me.
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
