5.0 overheating - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-17-2003, 06:21 PM
madhat's Avatar
5.0 overheating
My 93 5.0 w/ ac overheats while putting around town when the ac is on. It had a 3 core radiator cooling it, but I upgraded to a 4 core and it still overheats. It doesnt overheat as long as the ac is off. I have a fresh thermostat as well. Any ideas?
Old 06-17-2003, 08:56 PM
dmorris1200's Avatar
doesn't play well with others
Does your car have an electric fan for when the A/C is on. Usually most late model cars have an electric fan (either the main fan or an auxiliary fan) that should be on anytime the A/C is turned on. A bad fan relay could screw this up and cause you to overheat when the A/C is on.
BUILT FORD TOUGH
Old 06-17-2003, 09:38 PM
mustang66maniac's Avatar
Ford Freak
no electric fans on 5.0 mustangs, only the clutch driven fan.....could it be a bad clutch?
Old 06-18-2003, 01:18 AM
2-manytoyzs's Avatar
Start those projects someday
Last journal entry: Divco - has been on the back burner
Roll down the windows and turn the heater on full blast and see if the temp drops during the overheat condition. The heater acts like an extension of your radiator adding just a little more capacity to your cooling system. Check the knowledge base for more info on overheating.
Old 06-18-2003, 01:46 AM
horvath's Avatar
Acoustic Rock ... for real.
Last journal entry: About Fusible Links
If you don't have a shroud over your fan, you might consider adding one ... my temp was going up higher than I like with the AC on, too, and I was thinking about adding a shroud to my fan - it's the next step (in my mind) to best add cooling to the engine.
Alan
54 Chevy Pickup
Old 06-18-2003, 03:28 PM
gt2betubbed's Avatar
Kid With A Wrench...
Last journal entry: The Blower and test fit.
I would put in an electric fan in front of the rad that's hooked up to the ac switch that will make it turn on when ever the ac is on. If it works for most late model cars, y wouldn't it work for 5.0?
"Just my 2 cents"
Old 06-19-2003, 09:38 AM
madhat's Avatar
Thanks for the ideas. Do you think the fact that the whole driveline is setting at the wrong angle(trans too high, driveshaft scrapping e-brake line, engine tilting down to where it has rubbed a section out of the fan?) Do you think replacing the transmisson mount and getting a new clutched fan would help some too?
