5.0 Speed Density to 5.8 Mass Air Flow Conversion - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-07-2013, 07:22 PM
So I pulled the 5.0 from my truck (1987 F150 ECSB) a while back and was going to do some work on it, clean it up, and put it back in with a new cam, headers, maybe some GT40 heads, etc. Mild stuff. But i figured today, that if i am after more power, and planning on spending money anyways, why not just swap in a 351 and convert it to mass air at the same time? Shouldnt be too terribly hard I dont think.
The main thing right now is this. Will the 351 bolt in place of my 302? same motor mounts, same transmission, etc? What about the engine accessories? Will they transfer from the 302 to the 351?
And finally what about the engine harness. Can I get a harness from a 94-95 MAF truck... 5.0 or 5.8 and use it for the 5.8... or does it have to be 5.8 specific? I was thinking they were the same... probably need a harness from a 5 speed truck since my truck has an AOD and the 94-94s would be AODE or something else. What do you all think?
Old 04-07-2013, 08:22 PM
LATECH's Avatar
Last journal entry: GTO Reproduction Hood
Get a donor vehicle with the engine.
The accesories brackets are all different . The 351 deck height is taller, spreading the heads farther apart hence the acc brackets wont fit by about 1/2 an inch.
Wiring harness will be different as will the PCM the MAF is also SFI on that ,not batch fire like standard 5.0
tons of work and parts.
IIRC the 351 is externally balanced and so the flex plate /flywheel will be different.
Fact is stranger than Fiction
how to bypass a mass air flow and o2 sensor in a 96 chevy 80camaroguy Engine 3 09-12-2011 06:35 PM
87 Speed Density 5.0 Mustang packer fan Engine 1 01-07-2008 04:38 PM
mass air flow sencor/map sencor Lil Robert Engine 7 10-03-2005 07:11 AM
Mass Air Flow HerTA Electrical 3 05-23-2005 10:34 PM
convert from map sensor to mass air flow cgreene Engine 2 05-10-2003 07:29 PM
