Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 5.0 swap oil pan
Old 07-05-2004, 07:52 PM
DoubleVision's Avatar
DoubleVision DoubleVision is offline
Most Ford engines have a sump in the front because that`s where the oil pump is, so if you went to a rear sump only oil pan, you would need a longer pickup that reached to the rear sump.
