pan
I think you need to look for a pan off of a late 70's early 80's bronco or 4x4 pick-up. They are a rear sump pan. make sure it's a 302 pan and not a 351 pan because the front seal diameter is different..... And you will also need the oil screen(pick up) from the same set-up
