5.0HO build... suggestions? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-25-2007, 09:11 PM
OK, picked up a '90 5.0HO and am gettin ready to do a quick build before i throw it in my "special project". Here is the plans, the stuff with a * by it is just stuff i have laying around so i figure i might as well put it to use... stuff with a -, is stuff that is more or less free or just really cheap...
*MSD 6-BTM*
*T-70 turbo*
*A/W intercooler*
*40mm wastegate*
*BOV*
-custom single turbo headers-
-3" downpipe to dual 2.5"-
-port match heads/intake-
-ditching A/C-
-removing emissions-
40lb injectors
75mm throttle body
HEI distributor
MSD TFI coil
underdrive pulleys
FR 9mm wires
What should i do for a MAF? same size as the T.B.?
Old 04-25-2007, 09:24 PM
How fast is fast enough?
A/W intercooler? is it for a boat?
Old 04-25-2007, 10:09 PM
no?.?.? not for a boat?.?.?
going in my RX7. Ya lost me there...
Old 04-25-2007, 11:04 PM
1969NovaSS's Avatar
turbo lag......yeeeeehaaaaaaw
Is this the ebay t-70 or an actual t-70 with a t4 flange? If this is the ebay t70 with the t3 flange you will spool it extremely fast and choke the engine up top. I f its the t4 flange what ar is the exhaust housing. Dont forget to get it tuned before it even sees boost.
Old 04-26-2007, 12:53 AM
the flange doesnt make a difference, the turbine housing is a T4 .84 A/R
454 Build 48bill Engine 7 04-26-2011 04:53 AM
350 SBC Build Help Mustangsaly Engine 25 06-14-2005 07:52 AM
383 stroker assembly/variant to their suggestions 57NAPCO Engine 1 02-12-2005 11:23 PM
suggestions with pontiac 400 Angel1emt Engine 7 09-25-2003 12:08 PM
350 Chevy build Streetmachine Engine 11 12-10-2001 04:31 PM
