5/16 12pt nuts... what size socket??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-11-2011, 05:15 AM
v8hed's Avatar
AK427
I had to buy some 12pt 5/16 nuts for the corner studs on my SBC oil pan due to clearance issues. I purchased a 12pt 5/16 socket to tighten them with and it's far too small!
What's the story with 12pt fasteners? What socket size do I need to fit these 5/16 12pt nuts?
Thanks.
Old 05-11-2011, 05:28 AM
Last journal entry: Bringing home the 401 Nailhead
Thanks.
Are you saying 5/16 thread size? 5/16 nuts (thread size) usually take a 1/2" socket.
Old 05-12-2011, 01:20 AM
v8hed's Avatar
AK427
I did some Googling and eventually found an ARP link that stated 5/16 12pt nuts take a 3/8 socket. With every size fastener I've dealt with in the past, the size of the fastener is also the size of the socket/wrench you use on it. Why isn't that the case here?
EDIT: Having said the above, I've never really had occasion to deal too much with nuts in the past... is the size of a nut usually synonymous with the thread size rather than the size of the hex?
Old 05-12-2011, 06:57 AM
Irelands child's Avatar
The ARP fasteners will often take a different wrench size then the standard SAE fasteners, so it will almost be a trial and error. I have some 3/8" header bolts that take a 3/8" wrench where a normal would be 9/16". Since the UK kinda went to metric sizing, you will have to own a set of SAE wrenches to work on older American cars and equipment.
1/4"bolt/nut = 7/16" wrench
5/16 bolt = 1/2" wrench
3/8 bolt = 9/16" wrench
7/16 bolt = 5/8" wrench (or 11/16 occasionally)
1/2" bolt = 3/4" wrench
Here's a GOOD CHART that you can print out for your shop wall.
Dave W
Old 05-13-2011, 12:23 AM
v8hed's Avatar
AK427
Thanks for the link.
I do have a decent selection of AF/SAE tools, but 99% of my sockets are hex (as opposed to 12 point). Had to go and buy a pricey rail of deep 12 point AF/SAE sockets locally to get that 3/8 12pt!
Up until now, I've always known bolt sizes to be known by the size of the hex rather than the size of the thread. So, a 3/8 bolt would take a 3/8 wrench. What's different here? Is it because ARP fasteners have their roots in aerospace where perhaps the convention is to refer to the fastener size by the size of the thread?
Old 05-13-2011, 06:02 AM
I had forgotten why ARP uses smaller headed bolts but here is another link cold heading/grain stucture . You have to read between lines but it is pretty evident why they go this route. Almost every engine I have built has many ARP fasteners and I've never had a single failure. About the 12 point, most of what they offer comes either way, 6 or 12, depending on the use. Every fastener you see here is ARP and 6 point tho a few others on this engine are 12:
Dave W
Old 05-13-2011, 06:14 AM
v8hed's Avatar
AK427
I use 12-point where space constraints dictate a hex can't be used. On my engine, I had to use 12-points on the head studs as there wasn't room for a 6-point nut. Also, on my oil pan corner studs, I had to use 12-points. It's only when I started using 12-point fasteners that I realised that regular 6-point sockets aren't 100% compatible! Bummer.
Socket size stickers wheel-7 Garage - Tools 16 10-09-2012 08:01 AM
Torx socket size truckboy61 Garage - Tools 3 05-02-2010 09:35 AM
Hey I need the same size Ford lug nuts only smaller junkyard junkie Suspension - Brakes - Steering 4 02-08-2010 08:15 AM
what size are my torque converter nuts ? burnt olds Transmission - Rearend 4 02-25-2009 05:16 PM
Socket Size JT Rooster Interior 10 12-31-2004 09:27 AM
