5.3 or 6.0 swap - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 01-31-2011, 10:40 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
So don't procharge it. Find a roots or screw type blower.
  #17 (permalink)
Old 02-01-2011, 08:53 AM
the 5.3 cheaper and the iron version can be bored out to 5.7. It is also available in aluminum for a 100 lb savings. The 5.3 also is available with VVT, This advances or retards the cam for more power and efficiency at all rpm's.I would definitely use all the factory controls and learn how to deal with it. If you have any problems somebody will be able to help. I would check out (LS Tech. com) for all the information you will need. If you go to (Pirate 4x4) there is an article that describes all the engines.
LS1 Carb Swap and Cam Swap. Hacksaw Engine 27 12-15-2013 09:40 PM
456 gear swap to 373 in 8.5 rearend, carrier swap? leslie61 Transmission - Rearend 3 07-19-2009 04:45 PM
Tranny swap/ rearend swap? aggar Transmission - Rearend 2 03-16-2008 04:07 PM
86 K10 engine swap! swap tranny too? big_e111 Transmission - Rearend 3 08-03-2007 02:21 PM
to swap or not to swap? 78 Nova for a 75 wayfast77 General Rodding Tech 3 01-26-2007 07:33 AM
