5.3 - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-05-2012, 12:36 AM
im trying to put a small block chevy 5.3 in my 85 bonnie i would like to know wat size stall and gears should i go with it came out a 2004 tahoe
Old 03-05-2012, 01:53 AM
DR132's Avatar
Sophisticated Minimalist
is this a stock engine or are you planning on building it at all? really depends on what you want to do with it...
Old 03-06-2012, 12:59 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Also are you planning on using an OD automatic, or not? This will have a huge bearing on the rear gear ratio...
Anyway, assuming the stock 5.3 and using the tranny from the Tahoe, the stock converter will be tight- but that's not necessarily a bad thing for a stock engine, especially when you consider the cost for a good torque converter opposed to using the stock TC.
If max acceleration is your goal, there will be something to be gained by a slightly looser TC and =/>4.11 rear gears. The stock TC will have a lower stall speed in your lighter Bonnie, especially if the gears are lower (higher numerically).
