5.3 cylinder heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-26-2012, 03:01 PM
5.3 cylinder heads
what are these heads reffered to and will they work on a old 70` ish block using a vortec style intake. i`ve got a 383 motor with a 4 bolt main high nickel block with vortec heads on it and i`d like to take some weight off ... the 5.3 heads are aluminum and i thought they might be the ticket.
Old 10-26-2012, 04:18 PM
zildjian4life218's Avatar
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
I'm assuming your taking about the ls 5.3l and no they won't bolt up. Different bolt pattern. although I did hear about someone bolting them onto a sbf.
Old 10-26-2012, 04:34 PM
Last journal entry: was hoping for better than this
dart or world, can't remember what one.. but one cast a block to use the ls style heads on the older blocks..
cylinder heads ratrod47 Engine 4 11-20-2009 04:37 PM
SBC cylinder head bolts .. cast iron heads Vs Alum. heads terror385 Engine 3 08-04-2006 08:34 PM
Cylinder heads novatech Engine 2 03-19-2003 05:34 AM
Cylinder Heads Jeff Christenson Engine 2 03-10-2003 05:18 AM
Cylinder heads T man Engine 3 02-06-2003 06:54 AM
