5.3 LS engine - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-27-2010, 06:03 PM
bigdog7373's Avatar
Of course it's fast
5.3 LS engine
How are the 5.3 ls engines? I'm looking at buying a chevy truck with a 5.3 ls engine but it has 180,000 miles on it. I had the 6.0 and 8.1 and had no problems while i owned then for 160,00o miles. I've read that they have a metal head gasket so can the head gaskets blow on these engines or are they good for alot of miles? Any other info would be appreciated. I want to make a good purchase and the rest of the truck is in beautiful condition, i'm just a little worried about the mileage.
Old 08-27-2010, 07:25 PM
bigdog7373's Avatar
Of course it's fast
anyone?....
Old 08-27-2010, 07:55 PM
adantessr's Avatar
'23 T-Bucket Pickup
Last wiki edit: Troubleshooting ignition Last photo:
Wiki Edits: 3
Personally I would run a compression check on it and check the oil pressure with a manual gauge . If you like what you see . Buy it . I haven't heard of anybody having any problems with a 5.3 yet . But , Hey with 180,000 miles anything can happen . Then again , anything can happen with a brand spankin' new one as well . I'd check Kelly blue book to make sure the price is right for the mileage , etc.
Old 08-27-2010, 07:58 PM
bigdog7373's Avatar
Of course it's fast
Is there a simple quick way to run an oil pressure test? I don't want to piss the guy off by running a bunch of tests. I heard something about if you pull the oil cap of if oil comes out it's bad, or something like that.
Old 08-27-2010, 08:23 PM
If there's an oil pressure gauge- there's your check (most have the gauge as I recall). Run a compression test and that's about all u can do. Those are good engines but 180000 is a lot for any gas engine. If he used good oil and changed it regularly you should be fine- but many people get the cheapest oil there is every 5000 miles... if you do get it be sure to clean the fuel system out and change the fuel filter- that's rarely done and it can cost you a pump at that mileage.
Old 08-27-2010, 08:28 PM
carnahan's Avatar
i have a 2002 Z71 with the 5.3 in it. bought it with 58000 miles and it now has 140000. still runs great like the day i bought it. i don't know what year yours is, but if it has the same tranny as mine you might want to have someone who knows about them check it. i think it's a 60al or something like that. i had mine go out at 109000. of course it had the 100000 mile warranty. damn the bad luck. the guy at the tranny shop told me he does them all the time. pretty common. other than that my truck has been great, no other problems.
Old 08-27-2010, 08:31 PM
adantessr's Avatar
'23 T-Bucket Pickup
Wiki Edits: 3
As turbolover said , it should have an oil pressure gauge and if you just want to check for blow-by , you can remove the oil filler cap while it is running and there should not be any pressure blowing out. On a 'new' engine there is actually a slight vacuum at the oil filler caused by the pcv valve . That would be ideal , but no pressure is what you are looking for . Hit the throttle a time or two while you have the cap off also and watch for blow-by . I hope this helps .
Old 08-27-2010, 08:40 PM
carnahan's Avatar
maybe it's a 4L70E. not a 60al. that was a bad guess.
Old 08-27-2010, 09:00 PM
bigdog7373's Avatar
Of course it's fast
It has the 4l60e
Old 08-28-2010, 09:30 AM
carnahan's Avatar
thats the one
Old 08-29-2010, 02:58 PM
bigdog7373's Avatar
Of course it's fast
The thing is that i just had the head gasket go on my car and now i want a truck, so can an engine with metal head gasket blow a head gasket?
Old 08-29-2010, 03:08 PM
Any and all head gaskets can fail, doesn't mean it will.
Old 08-29-2010, 03:11 PM
bigdog7373's Avatar
Of course it's fast
Do you know if it's common at all on these engines?
Old 08-29-2010, 03:37 PM
techinspector1's Avatar
Wiki Edits: 326
If you don't get the answer you're looking for here, try googling "5.3 head gasket problem" and see what comes up.
Old 08-29-2010, 03:50 PM
Old Buzzard's Avatar
The head gaskets ..
are MLS design..[M]ulti [l]ayer [s]teel, and can take ALOT of abuse. Many 5.3, 6.0's w/ stock assemblies and turbos, blowers, making sky hi Hp. using factory mls gaskets.
When you are asking for history, maybe get the VIN # and ask a dlr to run a warranty history on it. A Carfax wouldn't hurt, either.
IMO, if the seller gets pi$$ed off about all the ??, let him hold it, and find another seller.
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
Buick 430 Engine 70LEBUICK Engine 5 02-24-2010 09:57 PM
Knowledge base Dave57210 Hotrodders Site Suggestions and Help 2 12-20-2009 07:06 PM
1985 C-6 truck tranny, no engine braking effect fast68 Transmission - Rearend 40 02-04-2008 05:55 PM
2000 Silverado 5.3 Check Engine Light Chevy_SS10 Engine 1 04-18-2005 10:39 PM
