5.3 ls motor swap in a 72 chevy c10 - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-02-2011, 12:41 PM
Has anybody did this swap with the stock pcm,& stock. Wire harness?
Old 02-02-2011, 03:18 PM
cowgirlup2's Avatar
a little dirt never hurts
hey
im not sure sorry
Old 02-02-2011, 03:40 PM
5.3 ls motor swap
Originally Posted by cowgirlup2
im not sure sorry
thanks anyway
Old 02-02-2011, 03:42 PM
5.3 ls motor swap
Thank you anyways
Old 02-03-2011, 01:52 PM
vicrod's Avatar
life is a ride
Last journal entry: LED tail lights
If the PCM, wire harness, engine and transmission are all from one donor vehicle they will work together.
You will need to add an electric fuel pump to obtain adequate pressure for the FI.
Also, a return fuel line will be required.
Get a shop manual for the donor vehicle at www.alldatadiy.com.
One note; The 5.3L (1999) had some issues with cracked heads, leaking intake manifold and piston slap. I would do some research on the engine you intend to use.
vicrod
82 Buick Regal Motor Swap To 85 Chevy 4.3 1badassgbody Electrical 18 09-08-2010 09:46 AM
Help! 77 Chevy motor swap questions! CokeZero Engine 49 08-11-2010 07:57 AM
chevy pickup motor and tranny swap rebel till death Transmission - Rearend 2 05-29-2009 06:39 PM
Chevy 350 engine swap – motor mount question 78transam Engine 4 06-04-2007 05:57 PM
Chevy BB engine swap motor mounts camarochas Engine 0 02-27-2004 09:15 AM
