5.3 ls vortec or lt1?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-16-2012, 08:32 AM
blackpanther68's Avatar
Okay so instead of going the gen 1 style block with the carb. I want my next motor 2 b fuel injected with either one of these blocks. My questions is which block is the better of the 2. The 5.3 truck motor or the lt1 4rm a z28? I kno the 5.3 is lik: e a 327 ci block and the lt1 is a 350 ci block. So my assumtion will b a 350 lt1 should b stronger. Althought the ls1 is an aluminum block. I just want some people to help me figure out which would b a BETTER SWAP FOR PERFORMANCE. I have the choice between the 2 motors I am stating but am not sure which one has better benifits of doggin someone.
I have viewed this edelbrock intake which allows you to take these blocks and use a carb on them but I think id like 2 keep them stock as is. So give me some opinions lt1 or 5.3 vortec?
Old 05-16-2012, 08:41 AM
Banned
The lt1 is an easier swap, the 5.3l is a better engine. The 5.3l will cost a little more but is better in every way except displacement.
Old 05-16-2012, 02:44 PM
Silver Surfer's Avatar
More machine than man
Last journal entry: bwaahhaahahaaahhaa
The LS motor is better. The truck version of the 5.3 LS1 is an IRON block. The heads are still aluminum though. The LS motor is stronger than the LT motor.
What would make a better engine for performance? I guess that depends on how much messing around with the computer controls you want to do.
Old 05-16-2012, 03:42 PM
I was thinking of maybe buying tht carb intake 4 these blocks with the little ignition module up there. Does anybody think a quadrajet 750 atop of the intake is plausible(+ what I mention below about a possible NOS system.
Okay to help me out with opinions as much as possible ima let you in on the scoop.
I have a ls 5.3 truck motor up @ a friends house for free. I've seen the motor and it already has the ls1 style intakeand fuel rails. I haven't been back to look at it more then tht 1st time b4 I come back . I don't kno if the block will crank over or start or anything yet yet but just the fact tht its been offered 2 me for free ima see what happens.
My cousin just gave me a nos carb sprar bar (just have 2 find extra hose,the bottle and gaskets etc) so I'm itchin 2 see what that will be like on either the 5.3 mostly but on an lt1 block if this 5.3 doesn't crank up.
I think tht would b a good swap into Black Panther ,than 2 keep foolin around with those gas guzzlin gen I blocks
Old 05-16-2012, 06:03 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
Why go through the work of putting one of those engines in your car if you're not going to take advantage of the fuel injection? As far as performance goes, the Vortec 5.3 is a truck engine and was never intended as a performance engine as delivered from the factory. While the LT1 was a hot engine in the 90s, by today's standards it isn't anything terribly special. These days there are a number of V6s that make more power.
As far as which is the better choice is up to you to decide. Both require their respective wiring harnesses and ECMs to run in the donor car. The LT1 will probably be the easier swap but the newer design of the 5.3 (especially the cylinder heads) would probably give it an edge in power potential.
Whichever engine you choose, consider leaving it almost entirely stock. If you get very far away from what the factory ECM is programmed for then you're going to have to spend at least $300 (probably more) on a custom tune from somebody like Blackbear Performance or ~$500 for custom programming software like LS1 Edit, HP Tuners, etc... if you choose to tune it yourself.
Old 05-16-2012, 09:49 PM
Banned
Slapping a carb on a stock lt1 or 5.3l vortec is plain dumb. The only change will be a worse tune and worse mileage. Its a losing proposition all around.
5.7 vortec in place of 5.7 lt1 beobbys Engine 4 04-26-2012 08:23 PM
vortec and LT1 heads webber Engine 7 03-08-2012 12:39 PM
Lt1 heads on vortec block Ugly89Camaro Engine 3 01-14-2008 09:53 PM
Vortec heads on LT1 the dan Engine 14 12-29-2007 04:24 PM
Lt1 intake for vortec heads? Newt408 Engine 1 12-06-2003 10:33 PM
