5.3 turbo build
hi im doing a turbo 5.3 build and im trying to do everything on a budget so i was wondering if anyone could give me any tips and a good source for parts thanks
^ no joke. its amazing all the things you over look and don't account for when you tackle a project like this.
You'd be surprised what a bone stock 4.8 or 5.3 can handle if tuned correctly. Look for the L33 series all aluminum 5.3. They can routinely handle over 900hp in factory form. A local at our track holds the fastest stock block record of 8.6x in the quarter. Also drives a 5000+ lb ford LTD with the same power plant and runs 9's at 141 mph. These both use untouched factory port heads and bottom ends. Cam, springs, head studs, and MLS head gaskets are the only eng mods.
Over on the turbo forums there are many guys in the 600-700 wheel horsepower range on almost bone stock standard 5.3s and 4.8s. Even reusing all factory HG and hardware. 100% factory untouched bottom ends. You spends all your money on the fuel system and management. Check this out if you get a chance.... it's as budget as you can get and the hotside looks like it was welded by and infant. Works great! Awesome build. http://www.theturboforums.com/thread...4l80e-9-95-141! |
| Recent Modern Electronic Engines posts with photos |
| Twin Turbo SBC build, need help | SBC S-10 | Engine | 27 | 04-21-2012 06:51 PM |
| Another V8 Bug Build....with a Turbo | 31fordcoupe | Hotrodding Basics | 53 | 12-12-2011 09:10 PM |
| Twin Turbo Chev Build | chevelle72tt | Engine | 37 | 02-04-2010 05:03 PM |
| Turbo 350 build | ssonny34@yahoo.com | Transmission - Rearend | 2 | 02-11-2009 01:42 PM |
| First Post,which is best for my turbo build? | SBOTurbo | Engine | 0 | 01-01-2009 09:35 PM |
