5.3l swap 91 caprice - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-20-2013, 11:16 PM
Ok im looking for as much info as I can for swapping a 5.3l into my 91 caprice. I know some info already about the swap but still a lot of info needed.
I want to keep my 700r4 because I just rebuilt it with a monster tans corvette kit. Will the bell house bolt to the 5.3l?
Is their a flex plate or torque conv. that will bolt to the 5.3l and 700r4?
Does anyone make a cable kit for the throttle and tv cable?
I watched a video of a guy do a 4 wire ecm harness to run the 5.3l should I do that or try to find a premade harness?
Old 09-21-2013, 12:25 AM
Proud LOSER
This might help
LS Swap Basics - Chevrolet Impala SS Forum : Chevy Impala SS Forums
Old 09-22-2013, 10:35 AM
The GEN 3 5.3 engine will bolt directly to the bellhousing of any GM auto trans, the info for the crank spacer, flexplate and 6 longer bolts is above.
GM Part Number 12563532) and 6 bolts (GM Part Number 12563533.
If you use teh correct flexplate, you will be able to use your torque converter you have.
I would be grabbing at least a 700r4 Corvette converter to get the stall speed up for the 5.3 due to its elevated torque/power bands. Or even a performance TC, but they can get exp[ensive for quality items.
A 4 wire harness must be for an afterm,arket control box. I think you need more for a GM ECM/PCM.
Good harnesses can be $600-$1000. EFIConnection does good harnesses, they use the real die sets for crimping their connectors.
TV cable for GEN 3 engines
Bowtie Overdrives - View Item
Lokar also makes TV cables. You might be able tow weld soemthing onto the GEN 3 LM7 5.3's throttle body to use a longer TV cable.
peace
Hog
trans swap in 90 caprice cudablack2004 Transmission - Rearend 19 06-01-2011 01:56 AM
96 caprice 8.5 swap to 86 caprice 7.5? brians407sbc Transmission - Rearend 6 08-13-2010 02:30 AM
87 chevy caprice frame swap cmjm03 General Rodding Tech 18 03-31-2009 05:52 AM
caprice axle swap sherman8r Transmission - Rearend 8 02-03-2009 07:53 PM
95 caprice rear end swap? molotov 350 Transmission - Rearend 2 04-08-2007 02:04 AM
