5.56 Rod strength Vs 5.7 - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 11-25-2008, 04:39 PM
topfuel's Avatar
ASE Certified Master Machinist
Last journal entry: More Pics
You will be fine with the stock length rods. I built a 406 back in the 80's that was somewhat similar to the one in the CHP story, at least the short block, and ran the heck out of it for 3 years before selling it to go big block. Here are some stats.
Forged TRW 9.5-1 comp. pistons
Stock length 5.565 rods recond. w/ARP bolts
Stock crankshaft
Comp Camps 280 Magnum hydraulic. 230°/230° @ .050 .480/.480 110° lobe sep.
186 Camel Hump heads (remember it was the 80's) 1.95/1.6 valves
Edelbrock Pro Ram II w/ 2 450cfm Holleys (9776)
I never spun it higher than 6000 rpm and it was bracket raced almost every weekend for 2 of the 3 years it was in my car.
The car was a 71 Camaro w/T400 and a 12 bolt w/4.10 gears. Besides the bracket racing, I drove it more than 400 miles one way to shows in other states on many occasions.
Oh, by the way. Did I mention the NOS cheater system that saw it's fair share of use.
Below is a pick of the engine.
  #17 (permalink)
Old 11-26-2008, 03:05 PM
I have been away from a computer for the past couple of days. Thanks everyone for your input.
Ron
  #18 (permalink)
Old 11-26-2008, 07:08 PM
I built a stock bottom end 400 this spring for my 82 Z-28 and I used the stock rods and crank. I did have new Speed Pro Hyper pistons pressed on the reconditioned rods with new ARP hardware installed. I used a Milodon stud kit in the bottom with studs for a windage tray. I am running Dart Pro 1 Aluminum 200cc heads with a retro hydraulic roller cam and lifters along with full roller rockers. Like you, I don't race the car, just have a lot of fun driving it and it runs strong and hard. I shift it 6000 when the need arises and so far, no problems, just a big ole smile when I am into it hard. Have fun..
  #19 (permalink)
Old 11-27-2008, 12:25 PM
The difference in rod ratios from 5.56 to 5.7 rod length is totally insignificant.
Unless you consider 6.0 rods the ratio is irrelavent, and then still not really good, just better.
Price to buy and assemble your rods should be your factor for using one or the other.
Your two carbs are perfect for your situation. Since they came new already calibrated for your setup, little if anything needs to be done.
Don't over cam your engine. You will hate it and wonder where your mid range went.
I suggest you avoid the dual pattern cams with lots of exhaust duration. That hurts down low to help a little up high, especially with the wide LSA they throw in to crutch the situation.
I think that you will be much more satisfied with a single pattern cam in the 224 to 230* range with a 108* LSA should give you a nice lopey idle and strong torque curve with easy shifting at 6000.
Rod length discussion, split from previous thread seriousracer Engine 11 06-29-2007 12:27 PM
Need longer rod ends. Can anyone help? 23TRex Suspension - Brakes - Steering 4 02-26-2006 03:34 PM
SBC Destroked Destroked_SBC Engine 46 02-19-2006 12:43 AM
removing rod end with metal dust cover/spacer cboy Suspension - Brakes - Steering 3 01-24-2006 03:45 PM
327 in 88 Truck pete379 Engine 101 01-19-2006 09:03 PM
