5 to 6 lug disk - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-26-2006, 12:32 AM
5 to 6 lug disk
Hello Every One. I have a 1949 gmc truck with a nova front clip (1976-79) The brake disks are 5 lug.I would like to have 6 lug (to match the rear end)with out going to a adaptor is thair a 6 lug disk that would fit my spendels new, used, aftermarket.I have 5 way cool wheels 6 lug so i dont want to change the rear end plus the rear has been rebilt. the truck has a new 350/350 i have all the body work dun wiring is next.please help if you can steve
Old 07-26-2006, 09:09 AM
No help from me ... but I would like to WELCOME YOU HERE ...
Deuce ... Moderator
Old 07-26-2006, 11:19 AM
Paddyboyy's Avatar
Any good machine shop should be able to remove the current studs and redrill for the six bolt you want.
Old 07-26-2006, 11:39 AM
gdubstub's Avatar
Old Crusty Streetrodder
...and cheap. I sent my rear axles to Moser Engineering, and even with shipping, I didn't pay over $75 for the fill and drill.
George
Old 07-26-2006, 04:10 PM
willowbilly3's Avatar
Last journal entry: Body mods
Also most of the 70s-80s aisian pickups use the same 6 bolt design so you might be able to make some of them fit.
Old 07-26-2006, 08:38 PM
RPM's Avatar
RPM RPM is offline
World Class ASE tech
didn't the GM 1/2 ton trucks about 1975 have 6 lug wheels. A front rotor off one of them just might work on your spindle. I don't know for sure but it might just fit right on there.
Old 07-29-2006, 02:40 PM
No, 2WD GM 1/2 ton pickups had 5 lug wheels. 4WD have 6 lugs.
Swap Drum to Disk Brake Ratoflic Suspension - Brakes - Steering 8 02-17-2006 12:24 PM
Change lug pattern on disk brake conversion? 68chevytrkr Suspension - Brakes - Steering 2 01-21-2006 03:12 PM
convert from 4 lug to 5 lug cesar9 Body - Exterior 7 11-25-2004 11:56 PM
Lug nut problems SOLVED!!!!!! willys36@aol.com Suspension - Brakes - Steering 3 03-15-2004 08:51 AM
6 lug to 5 lug on my shortbed mickfinch Transmission - Rearend 7 11-07-2002 07:07 PM
