5.7 383 or 6.3 383 - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-03-2008, 03:37 PM
5.7 383 or 6.3 383
what is the difference
Old 05-03-2008, 04:02 PM
SSedan64's Avatar
5.7 is a 350
Old 05-03-2008, 04:29 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
5.7 or 6.3?
Are you talking about Liters or rod length?
A 350 is 5.7L and a 383 would be about 6.3L
Old 05-03-2008, 04:32 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
5.7 refers to the liters of displacement. 5.7 liters is 350 cubic inches. 383 cubic inches is 6.3 liters
Old 05-03-2008, 10:32 PM
Haulin327's Avatar
I can fix that-
Pistons can be lighter with a longer rod but they may rock in there bores a little more... We have to keep a eye on rod weight as to not cancel out the bob-weight savings...crank counter weights can be lightend at that point and with a light flywheel or small dia. converter faster than normal engine response can be anticipated...
6.125 or so is about it for a 3.75 crank in a stock deck block... I would go 6 inch as you are not using super-shorty pistons.."tend to rock,burn oil,Race only...
Keep rod weight as lite as possibe...
all in all long-rod combos work in theary but to take full advantage You will have to have a stout wallet
Without the lite crank lite flywheel, and low gears and trick bob-weight style of balance job , the rewards of a trick long rod motor may not be met.....GO FOR 5.7 RODS.....
DR
Old 05-04-2008, 09:31 AM
DR
We builds a lot of 6.250 rod engines and there not burning any oil and if pistons are rocking in the bore that much would they make some noise and we have 2 engines with 6.300 rods in them and no problems.
If a pistons is fitted to the cylinder right there should not be any problem with pistons rocking in the bores, Remember the pin is higher in the piston not lower and if there was this problem with oil burning and pistons rocking in the bores you should see signs of this on the skirts over shorter rod pistons or if they are rocking that much they would break.
If these problems you speak of were true the piston companies would not build them as the engines builder would stop using them if there was a problem with burning oil and pistons rocking.
Right now after 30 years of building eignes we have not seen any problems you speak about with using long rods.
Curious what engines do you build that are having these kind of problems with long rods??
I have some new pistons on the shelf I will look and see if there is a warning about this problem of oil burning and pistons rocking in the bores on long rod pistons.
We buy alot of rods and there is no differance in price from a Crower 5.7 to a 6.0 rod and the same with the pistons we can buy a Mahle piston for a 5.7 or a 6.0 rod for the same money.
Old 05-04-2008, 02:03 PM
curtis73's Avatar
Wiki Edits: 16
There are often minor benefits to longer rods, but usually higher cost. It also slightly limits your piston choices. There are hundreds of 5.7" pistons for 383 but much fewer for a 6.0" rod. Not very many at all for longer rods.
Old 05-04-2008, 02:36 PM
Haulin327's Avatar
sounds great!
How much $$$$$ for one of your shortblocks???
Old 05-04-2008, 02:44 PM
Curtis maybe I am missing something here but I can buy a Scat 5.7 or a 6.0 rod for the same money and the same with a Wiseco or SRP or Diamond or Mahle piston 5.7 or 6.0.
But having to buy an weighted flywheel or flexplate and balancer cost quite a bit of money as well where you can use the balancer and flywheel or flex plate that came off your 350.
Most 5.560 and 5.7 rods and a 3.750 cranks are used the pistons are quite bit heavier and require exteranal balancing or if we have to add mallory to cranks to get them to balance internally which makes for a good money maker for us when we have to charge them for mallory and installation and when we charge them for a flywheel, flex plate and balancer its more profitable for us and not the customer. So there is a trade off !!
Old 05-04-2008, 03:33 PM
5.7 383 0r 6.3 383
i was on summit but it has a 5.7L 383 and a 6.3L 383. i know a 350 is a 5.7L and i know about rods being 5.7 or 6.0 since i have built a 383 stroker. i just wondering how can therr be a smaller liter 383 than a 6.3
Old 05-04-2008, 04:04 PM
Blazin72's Avatar
Wiki Edits: 19
i was on advance or summit one most likely summit but it hada 5.7L 383 and a 6.3L 383. i know a 350 is a 5.7L amd i know about rods being 5.7 or 6.0 since i have built a 383 stroker. i just wondering if there was another way that there could be a smaller liter 383 than a 6.3
No, liters and cubic inches are two different ways of expressing displacement. One uses the metric system and the other is the english system.
Old 05-04-2008, 05:38 PM
5.7 Or 6.3
what is the difference in a long block and a short one
Old 05-04-2008, 06:27 PM
Long block has the heads installed
Short block = No heads
Ok, here's the debate of the century: 383 or 400 chevy!! Cast your vote and reason killerformula Engine 303 03-28-2013 09:08 PM
5.565 or 5.7 Connecting Rods in 383 Chevy21 Engine 29 09-29-2008 06:25 PM
5.7 or 6.0 in a 383 280zxWith305 Engine 16 05-04-2008 10:32 AM
5.7 Vortec Mustangsaly Engine 6 12-07-2005 02:18 PM
383 Setup, need advice william27103 Engine 7 06-07-2004 10:57 PM
