5.7 in. rods with stock 400 crank? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-02-2006, 09:26 PM
Warrant's Avatar
72 Nova, 65 Rambler, 37 Chevy
I have a quick question,
Can I use stock style 5.700 inch rods with a stock 400 crankshaft? Or will their be counter weight clearence isssues or somthing?
Thanks!
Old 11-02-2006, 09:41 PM
Thanks!
With a longer rod the bottom of the piston should have more crank clearance
Old 11-02-2006, 09:46 PM
Warrant's Avatar
Alright...its just that I have seen cranks for sale that can't use the 5.565 rod, but can only use 5.7ss or 6's or longer....just made me wonder what was up.
Old 11-02-2006, 09:54 PM
On all the 383 cranks we buy we buy them for the 6 inch rod which allows us to internally balance the crank as it saves money on buying a special flywheel and balancer.
Old 11-03-2006, 11:42 AM
5.7 in 400 sb will require some extra grinding to get adequate clearence on several rods,4 of them i think.i used scat 4160 i-beam rods .but not that mush of a deal.Go for it..
Old 11-03-2006, 05:53 PM
the cranks setup for a longer rod use larger diameter counter weights.
Old 11-03-2006, 07:37 PM
techinspector1's Avatar
Wiki Edits: 326
On the pin end of the rod, check for interference of the balance pad with the underside of the piston crown.
On the big end, check for interference with the cam in the area of the rod bolt head and at the pan rail where the oil pan bolts up.
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
5.565 or 5.7 rods? JohnyR17 Engine 9 10-09-2010 07:17 PM
350 rods in a 400 85Sierra Engine 7 02-15-2005 08:07 AM
400 Crank sb72elcamino350 Engine 3 04-15-2004 02:42 PM
Mopar 361 BB bore, crank and rods? Bummo Engine 3 07-29-2003 12:23 PM
