5.7 TBI to Carb? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-15-2004, 06:28 AM
S10Fan's Avatar
Garage Filler
Last journal entry: I need more time!
5.7 TBI to Carb?
I have an 87 to 95 5.7 (350) TBI motor that I would like to convert to a Carburetor setup. The motor will be used in my 87 S-10. I realize Iíll need to make some changes to the fuel tank (fuel pump) and add an external electric pump but my main question is about the intake manifold. The 2 center bolts for the intake are at a different angle than earlier small blocks. Could I re-drill my intake (Edlebrock Performer) and make it work?
Thanks!
Old 02-15-2004, 06:46 AM
NorthStar's Avatar
I think Edelbrock makes a Performer intake for those heads about the only one to choose from nobody else does. Also you could run a regulator to lower your fuel pressure and not do anything with the gas tank. You would have to change some wiring on the relay though.
Old 02-15-2004, 10:52 AM
S10Fan's Avatar
Garage Filler
Thanks for the advice. I was wondering about using a regulator on the existing fuel pump.
Old 02-15-2004, 04:03 PM
Seon's Avatar
What distributor are you going to use? I hear that if you use an HEI, you'll need to change the gear?
Old 02-15-2004, 05:51 PM
You are referring to roller cam engines. If its hyd. cam it'll be fine.
If you already have the old style intake, you can elongate the center holes and it'll work just fine.
Old 02-15-2004, 05:55 PM
badknuckles's Avatar
you talkin to me?
actually on the factory roller motors from gm you dont need a bronze distributor gear.
you could run a 4-5 pd regulator with the feul pump and you can re drill your intake to work on those heads.
Old 02-15-2004, 06:22 PM
S10Fan's Avatar
Garage Filler
Thanks for all the replies. If you guys keep answering my questions this quickly I won't be able to put off doing the work! LOL!
Old 02-15-2004, 06:23 PM
you talkin to me?
there is always something to keep you from working
Old 02-15-2004, 06:42 PM
I'm not trying to be impolite but may I ask why you are deep sixing the TBI? I'm scouring the junk yards, trying to gather all of the bits and pieces to install a TBI unit on my stock 455 Olds! Frankly, I'm more than sick of my carb. You don't know this yet but that TBI has spoiled you. With the carb, you get to pump the throttle several times in the morning and have clouds of sooty black smoke choke you while the auto is warming up. And untill it gets darn good and ready, the motor will sputter and beltch and cough and might even flat die as soon as you put it in gear. If God forbid, you don't give the carbed auto a good warm up and try to pull into traffic, you'll end up spilling your large coffee moca that you got from Starbucks, all over your pants (try and explain that huge wet spot when you get to the office!). Also, you won't be able to afford that morning Starbucks because of the degraded gas milage, costing you a few bucks more a week. Sure, you can get your trusty shirt pocket screw driver and tune the carb's idle screws and choke in the morning but why bother, we are out of the stone age, let the O2 sensor and the computer do the tuning for you and enjoy your coffee while your engine purrs like a kitten from start up to when you pull into your gagage at the end of the day.
Old 02-15-2004, 06:52 PM
bondo's Avatar
Maybe, Just Maybe, S10Fan is a person who Knows How to Set-Up,+ Tune a Carb...............
Obviously You Don't fall into that catagory.......
Old 02-15-2004, 06:58 PM
I'd reply to your post about not having a clue as to the art of carb tuning but I'm too busy washing my coffee stained paints!
Old 12-06-2004, 09:25 PM
chrisflock's Avatar
Last journal entry: A quick trip
That's an exact description of what most TBI engines (that I've seen) do.
And it is usually a lot cheaper to switch to carb than fix a TBI system, unless you can score a free one that actually works right.
TBI is great, except when it breaks. I mean, what happens when the ol' ECU gives out? And don't tell me they don't, because they do. All computer hardware does eventually; it's the nature of semi-conductor chips.
Old 12-06-2004, 10:35 PM
ChevelleSS_LS6's Avatar
Jeep XJ and a Javelin
Last wiki edit: Compression test
Last journal entry: August 9, part III
Wiki Edits: 7
dont tell me fuel injection isnt all its made to be. My '71 briggs 8hp starts faster than a puddle of gas and a dropped match, even when it's around freezing outside if the carb is tuned right and all.
My car takes about a second to start one it gets cranking, and that's a sequential f.i. car.
gas mileage and performance isn't terribly different unless the carb is mismatched for the engine or poorly tuned.
Old 12-07-2004, 03:52 AM
S10Fan's Avatar
Garage Filler
Wow!
This thread is so old dust came out of my monitor! LOL!
I re-drilled the Edelbrock intake and it works just fine. After trying a few different carb combos I've settled on an Edelbrock 1407. The truck is a blast to drive and starts on demand.
Now it's time for bodywork.
