5/8th spark plug replacement for 13/16 rj12 yc
i have been use rj12 yc champions in my 440 for 10 years. they have the 13/16" base. is there a replacement 5/8ths mini plug recommended for header apps?
Wouldn't the threads be different?
Shane |
no , 5/8th meaning the socket required to remove it.
a 5/8" socket is easier to manuver around headers than a 13/16" |
Shane |
dont tempt me, man... i got a lathe, and know how to use it. the best smallblock head plug for me was the autolite 3929 tiny for those crazy fit headers. |
Could probabally mill a batch down quicker than you could find a set,also have you seen the sloted header plug sockets they have out now?
Shane |
gcrmcc |
okay "the grape vine" say bosch platiumun HR 8 BPX have the 5/8 mni "header plug" design.
anybody cobfirm this? |
Generally, the 5/8 plugs have the tapered seal, whereas the 13/16 had the flat spot and a washer. Find the right heat range and it would probably seal OK....
Ontario Rodders |
You need to decode the plugs you are running now and try to find another that has all the same attributes with the exception of the socket size. Any plug manual will be able to give you the heat range, reach etc.
My $.02 ------
Yesterday , i tried to get some plugs that were one range hotter than the CR45 ( A/C Delco ) plugs I normally use. The 46's had a 13/16th socket size and the 45's are 5/8" ..... the 13/16th's wouldn't thread in . I returned them for some good ol' 45's . |
| What spark plug should I run??? | Ratoflic | Engine | 6 | 05-25-2008 08:18 PM |
| Spark Plug Wire shortage??? | TheBreeze | Electrical | 10 | 11-04-2005 05:01 PM |
| Cylinder pressure vs. spark plug gap | 70bird | Engine | 3 | 05-28-2005 08:25 PM |
| SBC Spark Plug Suffix Question. | FBody | Electrical | 1 | 09-07-2004 03:27 PM |
| Weird spark plug situation?? | Jim Weeks | Engine | 4 | 05-13-2002 07:32 PM |
