5 blade or 7 blade fan: what's the dif? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-27-2005, 04:48 PM
pigjamelectric's Avatar
oldsmobile compatible
Last wiki edit: Selling your car Last photo:
Wiki Edits: 29
What's the difference between a 5 and 7 blade fan?
Old 07-27-2005, 05:57 PM
killerformula's Avatar
Last wiki edit: Carburetor
Last journal entry: Clean up
Wiki Edits: 3
uh... the difference is two blades.
K
Old 07-27-2005, 06:27 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Yep! Two Blades difference, LOL And it also moves a little more air.
Old 07-27-2005, 08:35 PM
Last journal entry: frame build
A 5 blade fan allows a certain amount of air to circulate around with the fan. A 7 blade does to but not near as much.
Picture it this way. The blades create a high pressure area at the leading edge that pushes the air between the blades in a circular motion. A seven blade doesn't have as much area between the blades thus flow more air.
Old 07-28-2005, 08:19 AM
johnsongrass1's Avatar
Race it, Don't rice it!
Too the poiint that air can't get in front of the blades.
It's really hard to beat a GM four blade for high fan air.
Old 07-28-2005, 09:12 AM
53LEDSLED's Avatar
here to learn
Last journal entry: finishing up the skirts
K
Erik, you **********
Old 07-30-2005, 06:28 PM
Wiki Edits: 29
The blades seem to be the same size and pitch. I'll go with the seven blade.
Thanks for the replies guys.
Paul.
Electric Fan Temp. Sensors horvath Electrical 26 04-26-2011 03:04 PM
Fan Clutch Bad After 400 miles? Ghetto Jet Engine 10 04-02-2005 09:21 PM
Clutch Fan malibuman66 Engine 18 01-01-2005 10:09 AM
electric fan or clutch fan?? mancinator Engine 4 06-02-2004 02:49 PM
EZ-Wire : Fan Connection horvath Electrical 11 03-28-2003 10:35 AM
