Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 5 link vette suspension
Old 11-27-2007, 05:59 PM
adtkart adtkart is offline
Techron.... You are right of course, in that it does not move with the suspension. Being mounted thru rubber bushings does not make it very rigid by any standards I know of. Without that connection to the trans, the pinion angle can change by probably 25 deg or more on that model. Some of the other years had plates that bolted directly to the frame. That was rigid.
